enviroment fog + density map + light selects = not working
  • enviroment fog + density map + light selects = not working
    Hello, I encountered an issues with the env fog in conjunction with light selects render elements. I have scene with an env fog and a procedural map to control the density of the fog. The fog doe not appear in the light selects of the two lights in the scene. When I remove the map it works fine. I tested it in 3ds Max as well and it works in Max but not in Maya. In 3ds Max I can use a noise map to control the density and the fog appears in light selects as well. Is it a bug in Maya?
    We are using: Maya 2019.3.1
    [2020/Jun/24|15:47:17] V-Ray: V-Ray Next for Maya, update 2.2 version 4.30.02 from Apr 15 2020, 17:49:01
    [2020/Jun/24|15:47:17] V-Ray: V-Ray core version is 4.30.03
    fog with noise map
Name:	envFog_0000_Screenshot (15).png.jpg
    Light select - no fog
Name:	envFog_0001_Screenshot (16).png.jpg
    fog without map in density slot
Name:	envFog_0002_Screenshot (17).png.jpg
    light select, this time with fog
Name:	envFog_0003_Screenshot (18).png.jpg
    thanks
    Florian Dubiel
    This seems like an issue on our side. I logged it under this ID: VMAYA-9725 for further investigation.
