Hello, we have scene in 3ds Max, some materials have a dirt node with values for the Z axis. When exporting the scene as a vrscene the axis do not get flipped in Maya, so the bias of the dirt material is still in z-axis and not y-axis in Maya :/ is this not working in general?
vrscene export from Max to Maya
really? isn't it possible to program it so that vray changes the axis automatically, depending from where the vrscene comes? In a vrscene there is a comment:
// Exported by V-Ray ADV Plugins Exporter
// V-Ray core version is 4.30.02 built at Apr 8 23:17:58 2020 b4e50a4
// Exported at Thu Jul 16 11:32:38 2020
// V-Ray GPU Next for 3ds Max 22.3.0.3165, update 3.2
// Frame at time 0
so vray should know to auto flip the axis when rendering with Maya for exampleno need to change the axis in Maya, that would be a smart solution
cheers
Florian
Thanks for the feedback. Indeed, it should. I've written an improvement request about the matter (internal bug-tracker id: VMAYA-9766) for our developers to investigate. Another workaround may be to use the VRayScene's scene overrides to switch the bias to the correct axis. In the following example, I've overridden the Z-bias to 0 and the Y-bias to 50 (original Z=50, Y=0):
Code:TexDirt Map__1@tex_0 { bias_x=0; bias_y=50; bias_z=0; }
