VFB input colorspace changes to RAW from ACEScg automatically
  • VFB input colorspace changes to RAW from ACEScg automatically
    Hello. After the change to the new VFB, Input Colorspace is reverted to RAW automatically from the OCIO profile loaded by the env variable. This happens all the time especially when using the denoiser. An immediate fix is necessary!
    Anybody noticed this?
    I have the same issue.
    https://linktr.ee/cg_oglu
    Ryzen 5950, Geforce 3060, 128GB ram
      Thanks for the report. I've logged the issue (internal bug-tracker id: VMAYA-9850). As a workaround, you can lock the parameters with these environment variables:
      Code:
      VRAY_VFB_OCIO_INPUT_COLORSPACE
      VRAY_VFB_OCIO_DISPLAY_DEVICE
      VRAY_VFB_OCIO_VIEW_TRANSFORM
        Code:
        What should the value be for those variables? I specifically want:
        Input Colorspace: ACES- ACEScg
        Display: Aces
        View Transform: sRGB
        Thank you
          The values depend on the loaded configuration file profile names (make sure the names match completely). With Aces 1.0.3, the desired values should look like this:
          Code:
          VRAY_VFB_OCIO_INPUT_COLORSPACE=acescg
          or
          VRAY_VFB_OCIO_INPUT_COLORSPACE=ACES - ACEScg
          VRAY_VFB_OCIO_DISPLAY_DEVICE=ACES
          VRAY_VFB_OCIO_VIEW_TRANSFORM=sRGB
            Code:
            or
            Thank you very much. What about Aces 1.1?
              Should be the same.
