Clipping a VrayAlsurface
  • Clipping a VrayAlsurface
    Looks like there are some troubles if i clip a object with a mesh applied with the same VrayAlsurface shader.
    https://linktr.ee/cg_oglu
    Ryzen 5950, Geforce 3060, 128GB ram
    Doesn't seem to happen with a default VRayAlSurface shader; maybe a parameter is causing it. Could you attach the scene here? Write your V-Ray and Maya versions as well.
      Here is the Scene.
      Im using Maya2020.2 and Vray 5.
        Thank you for the provided scene. It seems there is something the matter when clipping with SSS shaders. We'll investigate.
          Thanks for the update. Would be great to get this working.
