Vray5 normal mapping issue bump multiplier no longer works
  • Vray5 normal mapping issue bump multiplier no longer works
    it seems that when i set normal map to tangent space and apply a normal map to a surface its either on or off and the bump multiplyer no longer works. I can switch to normal map in object space and the multiplier seems to work again but there is no explanation of the differenaces between object space and tangent space so i do not know if this is correct or not?
    Bug or exspected behavour
    thanks in advance
    matt
    seems to work on the vray bump mtl but just not on standard vray mtl
      I have looked into this problem and it seems to be happening only with nightly build, but not with stable builds. Are you also reproducing the problem with nightly or stable build? I will have further look into the problem and report it for fixing.
        i just registered for 30day trial downloaded and installed.
        file is called vray_adv_50020_maya2018_x64.exe
        Im running win10, maya 2018 sp6 FYI
        about info within maya says the same
        cheers
        matt
          I have logged an issue (internal bug-tracker ID: VMAYA-9861) so our developers can have a look at it. Thank you!
            perfect thanks
              Is there any progress on this issue? My studio just upgraded to VRay 5 (5.00.20 August 5th) in Maya 2020 and I'm having the same issue.
                The issue seems to be fixed with the latest V-Ray 5 stable builds. Please if possible download and check if it works for you and if the problems still persists we will have a further look into it.
                  Where can I find the latest stable build.?
                    You can find the latest stable build (V-Ray 5 for Maya) in here: https://nightlies.chaosgroup.com
