Irradiance map viewer - Unrecognized map format
  • Irradiance map viewer - Unrecognized map format
    Hi!
    When I last checked the Irradiance map viewer was working fine, but now I'm getting this error message:
    Anybody run into this before?
    I can open the Irradiance map viewer application, but get this error message when I try to open a vrmap or vrlmap. And trying to open through Render Settings in Maya doesn't work either.
    Thanks!
    / Dan
    The standalone Irradiance map viewer seems to be working fine from what I tested. The button inside the V-Ray settings, however, does not indeed function properly; I'll talk to our developers about the matter. Otherwise, does this happen with an LC/IM generated from a fresh scene? If not, could you share the .vrmap/.vrlmap in question?
    EDIT: I've logged the button issue (internal bug-tracker id: VMAYA-9946) for developer analysis.
