Vray 4.3 VRayGeoSun not working
  • Vray 4.3 VRayGeoSun not working
    Hello, I wanted to use the vray sun with manual location override. Now we figured out that the position is totally wrong. For comparison I tried the same in 3ds Max (2020, vray 4.3) it works and it matches the real times for Los Angeles in this example, in Maya not at all. Is this a know bug in Maya 2020.3 ? cheers Florian
    [2020/Nov/2|16:13:20] V-Ray: V-Ray Next for Maya, update 2.2 version 4.30.02 from Apr 15 2020, 17:49:01
    [2020/Nov/2|16:13:20] V-Ray: V-Ray core version is 4.30.03
    Hello,
    We have a fix internally and it will go into the stable builds soon, you can track this issue with this internal bug tracker ID:VMAYA-9741. I will let you know when it's in the stable builds.
      This problem is expected to be fixed with stable build 4.30.03 from the 4th of November. Can you please check and comfirm for the fix or any other problems.
