Frame Buffer vRay 5 doesnt load or save images
  • Frame Buffer vRay 5 doesnt load or save images
    Hi guys !
    Does any body has any issues with the Frame Buffer 2 (vRay 5) ?
    The VFB2 doesnt save or load anything.
    Im using MaYa 2020.3
    Any suggestions, will be much appreciate.
    Thank you !
    DE: ERFINDER des Elektroautos „SION"
    EN: INVENTOR / FOUNDER of the electric vehicle "SION".
    Computer #1 (Main) : Windows 10 PRO │ 2xXEON │128 GB │Quadro M4000 │ Quadro K4000 │ MaYa │vRay 5 │Phoenix FD 4 │
    Even I have a powerful Computer ... I NEED CHAOS CLOUD !
    Hi XavBo,
    Can you provide a sample screenshot/screen recording along with the exact V-Ray version used? Was it working fine before? What is your OS?
    Nikoleta Garkova | chaos.com
      Hi Nikoleta,
      You can find the Video I create under this Link vRay5 FB doesnt save Images
      I dont know why doesnt save any images. I cant do anything. No load, not restore, etc...
        What you're trying to achieve (based on the video demonstration) is to save the image in the VFB Render History section. To do so, you will need to go to Options > VFB Settings > History and click on Enable. Make sure that the History folder path is existing, or use the Project Path option (see attached example).
        If you want to write the output files to disk from the VFB, you can do so with the Save current channel option as indicated here.
        Hope that helps!
          WOW !
          Ok, this also new !
          In the older versions of vRay you clicked save and you had the Image already there without thinking about the path.
          Understood.
          But now what means "Load to VFB" nothing happens there.
          How I can load Images that I already have ?
          About to save all different channels: I already understood that. Also a ppears a window where to save. So this one was easy.
          Big Thank you for that !
            The 'Load to VFB' option will load a previously saved image from the History in the VFB (same as double-clicking on the image). If you want to load an image from your machine and into the VFB, that would happen through File > Load image.
            You can read more about the new V-Ray Frame Buffer and its features here.
              OOPS !
              Oh boy I need to read more about the VFB2.
              Many things changed al ot from vRay NEXT
              Thank you a lot for your support and help.
