IPR with GPU fatal error
  • IPR with GPU fatal error
    it seams that Maya always crashes if you use GPU RTX mode with IPR. If I set a key it crashes, if I move a light it crashes, if I change the texture of the light it crashes...
    Does anyone else having this Problems?
    I use Maya 2019.3.1, Vray 5 nightly (vray_adv_50023_maya2019_x64_30493)
    The crash also happend with vray 5 nightly (vray_adv_50022_maya2019_x64_30471_install)
    I use 2x RTX 2080Ti (no NVlink) (Studio Driver 457.30)
    I'll install Maya 2020.4 and test it there as well. Hope it'll work.
    I also send the Scene to support.
    Cheers
    Tobias
    Hi Tobias,
    Thank you for sharing the files - we'll have a look and get back to you ASAP. Please also forward the crash dump files (check here on where to find them or how to generate them) so we can check them additionally.
    Nikoleta Garkova | chaos.com
      Hi Nikoleta, I sent you the Dump Files.
      Maya 2020.4 with the latest Nightly(vray_adv_50023_maya2020_x64_30493) does also not work.
      CPU Mode is working fine.
      Cheers!
      Tobias
