RemapValue's color output is broken
  • RemapValue's color output is broken
    RemapValue's color output (outColor) is not working correctly.
    Renders white, no output. Vray 4.5 and 5 - discovered the issue when I realised ramp values weren't being transferred to Houdini - but confirmed just now exclusively in Maya also.
    Plug a noise outAlpha into the input value of a remapValue node, add some random color values to the ramp, and output to any shader. The colors are ignored.
    Thanks for the report. There is something the matter when using textures to control the input values of a remapValue node. I've logged the issue (internal bug-tracker id: VMAYA-10087) for developer investigation. For now, you may need to control the colors through the texture itself.
