Ive been finding my noise render settings arent equal when using a denoiser. If I render on cpu bucket mode with production settings, without denoiser, my beauty will look smooth. If I turn on denoiser, as its rendering, the same settings will look grainy. Is this normal? Once the render is finished and it denoises the render, its a sub standard version of the non denoised beauty (rather than a smoother version of the non denoised beauty beauty) I assumed the render should look identical as a base beauty, except the added denoiser reduces grain further on the render to which it is added.
Is denoiser assuming that since its switched on, it can make some noise approximations to speed up the beauty?
Im using Vray 5 hotfix 1 on Maya 2020.
