Bake camera projection to 2d not working?
  • Bake camera projection to 2d not working?
    Hello,
    I am trying to bake a camera projection to a 2d texture with vrays bake options. Is this possible? The texture is not showing up when I vray bake. The vry bake shows the texture being baked when its a normal 2d texture but when its a projection it shows black.
    You're using a projection node, set to perspective, to load the image, correct? Seems to work fine on my end (see attached scene). Is this the workflow you're after?
      Thanks for the reply, I did have that set. Odd thing is I opened that file and the baking didnt work either. I am currently using maya 2019.3.1 and vray 4.30. not sure if there is something else on my end that is causing the issue.Click image for larger version  Name:	Screen Shot 2021-03-25 at 10.36.23 am.png Views:	0 Size:	903.7 KB ID:	1108632
        Hmm, you are correct. There does seem to be something the matter when baking through the V-Ray menu. Baking through Maya (set baking engine to Texture baking and click Render) does work though, so use it as a workaround. I'll investigate the issue further.
        EDIT: Logged the issue (internal bug-tracker id: VMAYA-10268 ) for developer analysis.
