Vray Plugin does load every time if i open a new scene.
  • Vray Plugin does load every time if i open a new scene.
    Somehow the Vray Plugin does load every time if i open a new scene. Even if i unload the plugin and the scene does not use Vray at all.
    There is no way to not load Vray if i opne a new scene.
    Im using the new Maya2022 version.
    https://linktr.ee/cg_oglu
    Ryzen 5950, Geforce 3060, 128GB ram
    Ok noone has this issue?
    Is there a way to find all vray nodes in a scene and delete them?
      Its not a good idea to delete the vraysettings node.
      I cant save my file now. I get an instant crash.
        Doesn't seem to happen on my end. Usually, V-Ray is automatically loaded only when opening a scene containing V-Ray nodes. Maybe some kind of a default setup with V-Ray nodes is opening?
          It seems i cant clean the maya file from vray.
            Have you tried the Remove Unknown nodes option (File>Optimize Scene Size>Remove Unknown nodes) with V-Ray uninstalled?
              Removing Vray is the solution.
