Aces result looks wrong- please help. HDR, VRscans..
    You have control over what is used for Color Picking in Maya,
    I have mine set to ACEScg so I can access all saturated Values that this wide Gamut offers
    Others would use Utility Linear sRGB .. which is fine as well
    By default it uses the View Transform for Color picking which has its own use cases, but could be problematic like what you said
    Honestly all of this knoweldge should be well known before using ACES, there is some reading you need to do
    Start with Arnold's ACES guide, then check ACESCentral on what you need more info on.. there are plenty of posts about "color picking" in ACES
    Next weekend I hope, I will have something out
    Muhammed Hamed
    V-Ray GPU product specialist
    chaos.com
      I feel like the color picker was the last thing I needed to figure out since I now have to have ocio env variable enabled.
      Switching that line in the OCIO file to Acescg now gives me a perfect match from color picker colors compared to a solid color texture i made out of photoshop with the same RGB values.
      thank you so much for all your help with this and I do look forward to any videos you come out with!
        Originally posted by Muhammed_Hamed View Post
        hmmm, did you setup Maya to use ACES in the color management settings?
        Can you show me what options you have in the file node ?
        Hey were is this? The forum doesn't allow to find posts so easily
        Maya 2020/2022
        Win 10x64
        Vray 5
          This Aces workflow is really a pain and confusing, I made some progress though but can we ever get the Hypershade to display the VrayMtl swatches in normal colors? it's all too dark. Also all the texture files are displayed darker, they are rendering correct but the swatches are dark.
          https://www.artstation.com/damaggio
