Maya Render View test resolution issue
  • Maya Render View test resolution issue
    Report the following bugs
    - Uncheck "Use V-Ray VFB"
    - Set the Test resolution in Maya's Render View
    - Hit Render. Rendering image is not output with the following error
    libpng error: Image width or height is zero in IHDR
    [2021/May/26|19:29:14] V-Ray error: Cannot write output image file "C:/Users/yama/Documents/maya/projects/default/images/tmp/無題.png": "internal error:6: internal error"
    Confirmed with Windows10 + Maya 2020 + Build 5.00.22 and stable_5.1.2 Build 30788
    OakCorp Japan - Yuji Yamauchi
    oakcorp.net
    v-ray.jp
    Hello,
    I have looked into this problem and managed to reproduce it, so I have logged an issue in our system for our developers
    to have further look into it. This is the internal ID bug number: (VMAYA-10415)
    Thank you for reporting this problem!
    Kind Regards,
    Dimitrina
      Thank you for registering for bug tracking.
      Please let me know if it is fixed.
      oakcorp.net
      v-ray.jp
        Will this issue be fixed? (Is it reflected in Nightlies?)
        Our customers want an early fix.
        Please give it a high priority.
        oakcorp.net
        v-ray.jp
          The same problem occurs with V-Ray 5, update 1 official.
          The bug was reported on May 26th, but wasn't it in time?
          oakcorp.net
          v-ray.jp
