Bug - Render Elements - not importing Preset
  • Bug - Render Elements - not importing Preset
    I am not sure if is a bug or my computer.
    I am using
    V-Ray 5 for Maya, update 1
    (v5.10.20 from Jun 15 2021)
    Bug is:
    V-Ray Render Elements TAB CAN save Render elements PRESET.
    BUT
    It is not ABLE to Import the preset saved -> render_elements
    It is just me or someone else is having the same problem?
    Error in the script editor states:
    requires -nodeType "VRayRenderElement" -dataType "VRaySunParams" -dataType "vrayFloatVectorData" -dataType "vrayFloatVectorData" -dataType "vrayIntData" "vrayformaya" "5";
    // File read in 0.065 seconds. //
    Hey Tyros,
    You can select the REs you wish to save and in the Render Settings dialog open Presets > Export AOVs. You can load them back by the Import > AOVs option.
    Nikoleta Garkova | chaos.com
      There does seem to be an issue when importing render elements through the Render Settings. The occurs when the "Render Setup" (the new render layers) profile is active with recent V-Ray builds. The issue is not present with the "Legacy Render Layer" system. I've logged it (internal bug-tracker id: VMAYA-10556) for developer investigation. As a workaround, you may follow Nikoleta's suggestion.
        Hi Nikoleta and Hermit.
        I did not know about the <Presets <Export AOV and Import AOV. Used to be only RenderPresets save on that tab. and using json.
        I am thinking to know if this JSON would work to import in other applications and have the same presets like in max or Houdini.
        Thanks a lot for the help
          Hi! As we encountered this "feature", we've changed the pipeline tools to reference the Maya-file with needed AOV nodes and turning on the "Use referenced" checkbox in Render Elements settings.
          Code:
          PyMEL example:
          import pymel.core as pm
          pm.createReference(aov_file_path, groupLocator=True, namespace=':')
          pm.SCENE.vraySettings.relements_usereferenced.set(True)
