VFB Composite ExtraTex RenderElement and Dirt : Black result
  • VFB Composite ExtraTex RenderElement and Dirt : Black result
    When i add the renderElement "extraTex" with a vrayDirt assigned, in the VFB composite layers, set to multiply...its just black. I saw in the 3dsmax forum, a solution where you need to add a rgb renderelement layer underneath to get it to work...which is does. Only problem is, that rgb layer destroys any changes made on other layers below.
    How am i meant to comp the dirt layer?
    e: info@adriandenne.com
    w: www.adriandenne.com
    Put the RGB layer below everything.
    Yavor Rubenov
    V-Ray for 3ds Max developer
      thanks bud..i wish i had tried that
