Vraytr_usd_translator.dll error in Maya 2022.1
  • Vraytr_usd_translator.dll error in Maya 2022.1
    Maya 2022.1 update with V-Ray update 1.1 [Build 5.10.21] gives a missing Procedure entry point error in vraytr_usd_translator.dll,
    and the latest Nightlies 20210729 also gives the same error.
    We are waiting for the release of the update patch.
    Click image for larger version  Name:	2021-07-29_144752.jpg Views:	0 Size:	37.4 KB ID:	1120738
    OakCorp Japan - Yuji Yamauchi
    oakcorp.net
    v-ray.jp
    It seems that 2022.1 comes with MayaUSD 0.10.0 - a version of the MayaUSD plugin that's newer than what V-Ray supports and that's why you see the error.
    Otherwise, V-Ray will work fine in 2022.1, it just won't work with MayaUSD.
    The 2022 version (with no updates installed) comes with MayaUSD 0.8.0, which works with V-Ray. There is also a 0.9.0 version that's also compatible.
    I can suggest either moving back to 2022 (with no updates) or manually uninstall MayaUsd 0.10.0 and then manually install MayaUsd 0.8.0 or 0.9.0 (you can get the installers from Autodesk's MayaUSD github page: https://github.com/Autodesk/maya-usd/releases ) until we release an update that supports 0.10.0.
    Alex Yolov
    Product Manager
    V-Ray for Maya, Chaos Player
    www.chaos.com
      Hello, Mr, Alex
      Thank you for solution advice up to MayaUSD 0.10.0 support.
      oakcorp.net
      v-ray.jp
