EXR Color Management
  • EXR Color Management
    Hello
    I am having a Gamma/Color Issue when saving EXR Files.
    Did the color management change lately.
    So far I had perfect matching colors from Vray Framebuffer to other Programms (Photoshop, AE, ...)
    but lately I get washed out colors when saving out EXR.
    This doesnt happen when I save in other formats (jpeg, png, tiff)
    Perhaps I missed some new setup/workflow
    Thanks
    Martin
    Hi Martin,
    here is an tutorial how you can apply a view transformation in PSD to get perfectly matching colors:
    https://www.youtube.com/watch?v=dksSrFWxLr4
    For AE/PSD there are OCIO plugins available:
    http://fnordware.blogspot.com/2012/0...r-effects.html
    http://fnordware.blogspot.com/2017/0...photoshop.html
    Hope that helps,
    Lars
      thanks for your reply
      I installd the OCIO plugin and it works fine
      as this has not been necesarry before, I would like to know,
      if it is possible to reset Maya/Vray to the "old" settings, so I can open EXR in AE/Nuke without a plug?
        Hello,
        Yes it is possible,
        Then swap the frame buffer to sRGB instead of sRGB, this was the default in older versions of Vray
        On another note, Nuke don't need a plugin to use ACES. Nuke 12 and 13 come with ACES 1.1
        ACES has many advantages in Vray when it comes to saturated lights, tone mapping and wide gamut rendering, it is just that Photoshop lacks color management at the moment hence it is a little harder to use ACES there
        Best,
        Muhammed
        Muhammed Hamed
        V-Ray GPU product specialist
        chaos.com
          thanks for your explanation in depth
          I totally see the advantage of OCIO / ACES and for sure PS/AE will come up with a native connection in the near future.
          have a great day
          Martin
