Discrepancy between physical camera F-number and camera override Aperture value
  • Discrepancy between physical camera F-number and camera override Aperture value
    At our studio, some productions are done with the Maya standard camera, and some are done with a V-Ray Physical Camera. We've noticed that the depth of field-effect do not match up, when we expect the values to be "equal".
    In the V-Ray for Maya documentation, the "aperture" value within camera overrides (for Maya standard cameras) is said to be the size of the aperture in world units. World units are cm per default in Maya. So a value of 1.25, for example, means that the aperture is 1.25 cm. Is this correct?
    When we tried to match this value with a Physical camera, however, they did not match. To get an aperture size of 1.25 cm, I set up a camera with a focal length of 50 mm (5 cm) and an F-number of 4. This should mean the aperture size is 1.25 cm (5/4). Why is the effect not the same? Have we misunderstood something?
    I've attached an image to give a visual example of the issue. I created a camera, set the focal length to 50 mm, film gate size to 36 x 24 mm and the focus distance was 10 cm. Then I duplicated the camera, and made one copy a V-Ray Physical Camera with the F-number set to 4. The Aperture value in the Camera override for the Standard camera was set to 1.25. The two renders have been cropped along the white line to show the difference.
    It is quite obvious that the Standard camera gives a stronger DoF-effect, i.e. less is in focus.
    Maya version is 2019.2
    V-Ray version is v 4.30.03
    Hello,
    Is it possible for you to send a scene, with which you are able to reproduce this problem?
    Kind Regards,
    Dimitrina
      Hi Dimitrina. The forum does not allow me to upload an .mb-file. What is the preferred method of sharing a scene?
        Hello again,
        You can send the scene to dimitrina.milanova@chaosgroup.com or to log it into our support submit request system here: https://support.chaos.com/hc/en-us/requests/new
        Kind Regards,
        Dimitrina
          I've sent you an e-mail Dimitrina.
          As previously stated, the scene was built and tried with Maya 2019.2 and V-Ray for Maya v 4.30.03.
            Hello,
            The physical and standard camera models in V-Ray are quite different and the results are not expected to match. The DoF in the physical camera depends on multiple factors and not just the aperture, f.e. the film size. The standard model is much simpler.
            Radoslav Platikanov | Chaos R&D
              Thank you for the answer Radoslav. Now we know not to interchange between the two.
