I seem to be having a lot of stability issues with the latest version of V-Ray GPU and Maya 2022. A lot of the time when I use the IPR renderer the renderer hangs and then it hangs up Maya after it gets past the 'Compiling Kernels' stage, it can also just make Maya disappear without warning.
I've found that I can render still frames ok (mostly), but the IPR render crashes then I get the error message: // Error: line 1: V-Ray : Unhandled exception occurred, will exit render loop.
I'm running the recommended Nvidia Studio driver on an RTX2080Ti, Windows 10 Pro 21H1, AMD Threadripper 1950X.
I've also had issues where the V-Ray GPU won't render unless motion blur is switched off, which can be problematic when it comes to rendering animations. I'm not sure if anything can be done to help all this but thought I ought to make it known...
Edit: Also I'm seeing this message a lot, it's making progress incredibly slow when I need to do is render a super simple scene - basic geo, some fairly simple shaders and dome light. // Error: V-Ray : There was a fatal error rendering the scene.
