Certain objects failing to toon render
  • Certain objects failing to toon render
    I'm not really clear what the Toon node is or how it works. It's not a shader, and it doesn't appear to be a set. So I'd assume then that anything visible in the scene with it activated should render with it (absent any exclusion sets, which I don't have).
    I'm not seeing that and I've had a few instances of things simply not rendering in the toon pass despite being visible and with no other factors apparently in play.
    Can anyone advise what's going on?
    [Edit] Hm, this may in fact have been down to lack of shading assignment on a render layer....
    If you still have issues with you could share your scene with us so we could take a look.
    Nikolay Kusht | chaos.com
    Team Lead, 3D Support | contact us
