VRayTriplanar does not reflect Proxy Transform
  • VRayTriplanar does not reflect Proxy Transform
    In "Build 5.20.01 V-Ray Production Render", VRayTriplanar does not reflect Proxy Transform.
    (Same for Nightlies 20220107)
    V-Ray GPU Render has no problem.
    Attach sample scene
    Could you confam.
    OakCorp Japan - Yuji Yamauchi
    oakcorp.net
    v-ray.jp
    Thanks for the report. The issue is reproducible and concerns the New V-Ray Proxies in conjunction with TriaplanarTex's Local Object space; I've logged it (internal bug-tracker id: VMAYA-10986) for developer investigation. As a workaround, you can either switch back to the old V-Ray proxies or set the Space to Reference Transform and control the size through a reference object.
      Thank you for adding to the bug tracker.
      By the way, the same problem occurs with the old V-Ray Proxy.
      I hope it will be fixed soon.
      oakcorp.net
      v-ray.jp
        Huh, tested it again (v5.20.01) with the old proxy, however, it seems correctly mapped (using your scene and .vrmesh). Could you attach the scene with the old proxy so I can include it in the log?
        EDIT: Typo in build version.
          The latest version I can try is stable_5.2 Nightlies 20220107 build.
          Attach scene and log
          oakcorp.net
          v-ray.jp
            Thanks for the scene. Quite odd. When importing the .vrmesh on a fresh scene, the issue does not occur. I've included the scene in the log and notified the developers.
