VrayTexOSL not working on renderfarm
  • VrayTexOSL not working on renderfarm
    i cant get osl to work on our farm. Environment-Variables are set properly to:
    VRAY_OSL_PATH_MAYA2020=C:\Program Files\Chaos Group\V-Ray\Maya 2020 for x64/opensl
    And the files are there.
    But i get the error:
    ERROR: Attempt to load shader "X:/_resources/_textures/OSL/Flakes2.osl" with empty OSO data.
    WARNING: V-Ray error: VRayTexOSL2 :: [OSLIntegrator::makeOSOFromString] -3: Could not find stdosl.h. Please check VRAY_OSL_PATH_MAYA2020
    Any ideas ?
    Thanks,
    Andy
    Hello,
    Can you please send us a bit more information about the Specs you are using such as: V-Ray version + build number,
    Maya version and OS you are reproducing the problem with.
    Also are you using a ZIP installation and if yes, is it possible to try again, but to uninstall the normal V-Ray for Maya
    installation (to clean any leftover settings) and then install the ZIP builds + try to reproduce again?
    Kind Regards,
    Dimitrina Milanova
