Ipr and textures not updating.
  • Ipr and textures not updating.
    So the issue where, if you have a texture rendering in ipr mode (gpu), and you change the texture using maya's filenode dialogue, it doesnt update in the ipr, unless you restart it. Has this been fixed in the nightlies at all?
    If you connect a new file node, the ipr updates fine, just seems to be if you change the file/ path etc in mayas dialogue window itself.
    e: info@adriandenne.com
    w: www.adriandenne.com
    Hello,
    This issue is supposed to be fixed with the most recent V-Ray nightly and stable builds (52002).
    Is it possible for you to test it with any of the builds mentioned above?
    If the problem is still reproducable, please do not hesitate to contact us and we will have further look into it.
    Kind Regards,
    Dimitrina Milanova
      i will, thanks for the info..much appreciated.
