Intel 12900K Vray render node low CPU usage issue
  • Intel 12900K Vray render node low CPU usage issue
    I recently installed Intel 12900K CPU on one of Vray (for Maya) render node machines. When I start a render from my main machine I noticed that not all cores are running on 12900K. Turns out only E cores are being utilized while P cores are sitting idle at 0% making render times very inefficient.
    I suspect this is because with the new Intel P/E cores architecture CPU is treating Vray slave service as a background process hence only using E-cores which are very slow for rendering. Is there a way that Vray could force this CPU to use 100% of its cores?
    Currently I am running Process Lasso app to force CPU to use all the cores with Vray, but I would very much like to have this working without using another app.
    I'm using last version of Vray Next and Maya 2018
    Check this thread.
      An update to the linked thread contains an unofficial fix, and the official Chaos stance on the issue.
      https://forums.chaos.com/forum/v-ray...39#post1143539
      Lele
      emanuele.lecchi@chaos.com
      Disclaimer:
