Weird cutoff in bercon noise pattern when rendering with CPU.
  • Weird cutoff in bercon noise pattern when rendering with CPU.
    What is happening here??? You can clearly see a line in the water where the bump stop when rendering with CPU. With GPU there isn't an issue.
    Thanks for the report. The issue is reproducible and is directly related to the VRay Bercon Noise map (used as bump on an infinite plane). I've logged it (internal bug-tracker id: VMAYA-11134) for developer investigation.
      Had the same issue recently.
      thanks for investigation!
        This problem is STILL not fixed. This does not only happen with infinete planes but also geo.
