Blend Material Keying
  • Blend Material Keying
    I Keyed the Opacity of a blend material. It works when I render in Maya, but when I batch render (mayabatch) it doesn't work.
    Any workaround ? (I will try keying blend amount instead)
    www.mirage-cg.com
    If also blend amount won't work, maybe you could instead duplicate the material, apply Material Switch node and keyframe it.
    My Artstation
    Whether it is an advantageous position or a disadvantageous one, the opposite state should be always present to your mind. -
    Sun Tsu
      Thanks, I will try this if it doesn't work with blend amount
      www.mirage-cg.com
        ah, btw, animation blend amount works with Mayabatch...
        www.mirage-cg.com
          lol, who would have thought xD (no sarcasm)
          My Artstation
          Sun Tsu
