Zooming in with camera (Physical Camera) change the exposure?
  • Zooming in with camera (Physical Camera) change the exposure?
    I think that's something I noticed in past with VRay Next or the previous... Don't quite remember which one.
    Anyways... I wonder if anyone ever experienced that and let me know why zooming in/out with the camera changes the exposure or brightness? Not really sure which one but you can see that something is wrong.
    If I get even closer, the render turns black as if the exposure was set to 0 or something.
    In any case and in my opinion, it's definitely not a desire effect.
    https://player.vimeo.com/progressive...4cbe5c0f9bfcc8
    Best,
    Jacques.
    There’s a setting there in the camera you need to check but I’m away from computer now. Look for Specify Focus option
    https://www.artstation.com/damaggio
      Thank you damaggio!
      I reckon "Specify Focus" is for DOF, right? I don't use DOF for that camera so am not sure that's what causing the issue.
      I also noticed that if I change the "zoom factor" directly in VRay physical camera, it doesn't change the exposure... Neither the focal length affects it.
      Cheers,
      Jacques.
        Sorry Jacques, I rarely use a physical camera and this "Specify Focus" I learned from the Razorcrest lectures found here.....https://www.youtube.com/watch?v=CPwz...4jfqwL&index=3
        Someone from Chaos should give you a better response. I'll keep watching the post
          This should shed some clarity.
            Thanks a lot Aleksandar!
            I checked the Maya doc and that section with exposure/distance explanation doesn't exist and I didn't know it was happening in real life neither.
            Cheers,
            Jacques.
