Triplanar + UVW Randomizer Texture Swims
  • Triplanar + UVW Randomizer Texture Swims
    I'm using a grunge map on a character that uses the UVW randomizer plugged in to the texture, then that is applied to the character with VrayTriplanar. I've rendered out my character, that is rigged using a mixture of joints and bend/squash deformers, but when it's rendered the grunge texture seems to swim around on the character.
    Is there a way to stop this from happening?
    Images attached show my setup...
    You need a rest position. Which you should be able to connect to the "node ref transform"
      Thank you, I'll give that a try!
