samples per object
  • samples per object
    Is there an other way than using the object properties to set a subd multiplyer?
    Cause an object can only be in one object properties set.
    https://linktr.ee/cg_oglu
    Ryzen 5950, Geforce 3060, 128GB ram
    Could use render layers and set an override.
      Interesting workaround but not a solution. At least in my case.
        The VRayMtlWrapper has most of the VRay Object Properties' options - maybe it could come in handy. What exactly are you trying to do?
          Id like to increasy the multiplyer for our ss shaders.
            OK i see on GPU there are no Addition Surface Properties available at all.
              Sorry to say, yes.
                Hey oglu
                What did you use to setup your SSS ? Alsurface? Translucency?
                Would it be possible to share a sample scene, or show us how your frame looks like?
                We need more information to be able to assist
                Best,
                Muhammed
                Muhammed Hamed
                V-Ray GPU product specialist
                chaos.com
                  Here is a typical scene. The skin torus does just take longer to converge.
                    Thank you for the scene, I didn't forget about this
                    Still open to discussion with the GPU team, to find a solution
                    Best,
                    Muhammed
                    Muhammed Hamed
                    chaos.com
                      Any news about the issue?
