Object properties "Matte Object" not rendering as before.
This topic has been answered.
  • Object properties "Matte Object" not rendering as before.
    I'm doing some testing with Maya 2022 and Vray 6.00.02 on a scene that was previously set up using Maya 2020 and Vray 5.20.01. Objects that are part of an object properties set that are set to "matte object" and with alpha set to black hole (-1) are now knocking out their corresponding pixels from the image plane, resulting in black. Previously these parts of the image plane would render as normal into RGB. For previewing purposes etc. it is undesirable to have them render this way.
    Is this by design, and if so what is the thinking behind it? Seems like this was working fine before, with the pixels in the image plane rendering into the RGB being the most intuitive and desirable result. Is there a new setting/workflow to attain the previous behavior?
  • Answer selected by hermit.crab at 02-03-2023, 02:17 AM.
    Yes, we are aware of the issue. It's already logged (internal bug-tracker id: VMAYA-11551) for developer investigation. I guess you could work around it by using a background environment override instead.
      Just in case a visual explanation is needed:
          Ah, OK. Thanks for the confirmation it's not a new "feature" or I'm doing something wrong. Does this only occur with Vray 5 to Vray 6 conversions, or is this native to Vray 6?
            Introduced in V-Ray 6. It used to work for V-Ray 5.
