CPU vs GPU rendering results
  • CPU vs GPU rendering results
    So one of my artists handed off a scene that he put together and when I render I get different results between GPU and CPU rendering:
    CPU (correct):
    GPU:
    HOWEVER, my artist says that he is getting the same result with CPU and GPU renders.
    He has a older GeForce card (2070 Super) while I have a 3070.
    Do you have all the textures on your end? If he's getting identical results, it's probably a file location issue; maybe a permission one.
      Yeah, the scene was archived up into a zip and everything is loaded (I checked the File Path Editor). I also full privileges on my machine.
        Are you rendering with an identical V-Ray and host platform version? Maybe you could attach the scene so we can take a look.
          Here you go!
          https://drive.google.com/file/d/1Dba...ew?usp=sharing
            Allow access so I can download it.
              My bad. Try it now:
                Any luck opening it?
                  The differences are strictly linked to the VRayBlendMtl:
                  1. The VRayBumpMtl without a base shader (Airfeild_Normals_Spacing) is handled differently on CPU and GPU. Both do not work without a base shader. The major differences stem from here.
                  2. Opacity is not supported on GPU with VRayLightMtls (Dirt_Map_RGB_Overlay_mat)
                  3. MS_Soil_Mud has a normal map linked to the bump slot, but the mode is set to Bump.
                  Note that GPU and CPU handle normals differently, so differences are inevitable. Otherwise, we suggest choosing a render engine based on the needs of your project and sticking to it, rather than switching engines mid-production.
                    Thanks Aleksandar for taking a look at that.
