Vray Renderable Curves and render layers
  • Vray Renderable Curves and render layers
    There seems to be an issue with assigning renderable curves to render layers
    I have two building plans, ground floor and top floor.
    Each plan is on it own render layer.
    On rendering one of the layers it simply renders all the plans in the same render, so render layers dont respect the assigned curves.
    The work around is to set a layer override for the visible layer for the display layer. But shouldnt need to ...right?
    Cheers
    S
    Thanks for the report. I've logged the issue (internal bug-tracker id: VMAYA-11794) for developer investigation.
      Hello stezza,
      This problem should be fixed with the most recent V-Ray for Maya nightly build.
      Is it possible for you to check on your side? If the problem is still happening, we will have further look into it.
      Kind Regards,
      Dimitrina​
