The rendering is suddenly coming out dark
  • The rendering is suddenly coming out dark
    What is wrong? (The setting is the same)
    The version I use is vray for maya 2020 / vray 5
    It's hard to say without a scene. What do you mean by suddenly?
      After setting up animation frames 1-350
      Rendering with render sequence successfully.
      It came out normally from 1-70.
      After stopping rendering for a while,
      Rendering has been successfully invoked.
      71-350 on the render sequence
      It suddenly comes out dark from frame 71.
      Other than the frame setting, the settings are the same.
      How do I get it to come out normally?​
        Best you send a simplified version of the scene (only one object exhibiting the issue should be fine) so we can troubleshoot.
          have you got auto exposure turned on?
          Website
          https://mangobeard.com/
          Behance
          https://www.behance.net/seandunderdale
            I'm using V-ray's physical camera
              I was referring to the auto-exposure feature in render settings - overrides tab - Auto Exposure. If that is on, and you render one frame, stop the render, render another frame, you'll likely get different exposure results.
              Website
              Behance
