Vray 5 Color Mapping Clamp issue
  • Vray 5 Color Mapping Clamp issue
    Hi, in older versions of vray we got "clamp settings" under "Color mapping settings" to get rid of attached image issue.
    We use to get bad leaf transparency back to sky or background cause of the brightness difference. How can we solve it now in vray 5.0?
    Thank you.
    HI, thanks for posting. This is the VRaySky right? I mean there is nothing done in post? You could try the Max transparency levels:
    Vladimir Krastev | chaos.com
      Hi, thanks Vladimir,
      but has nothing to do with transparency levels. Its more about a difference brightness. In past versions we could fix it clamping the max brightness under color mapping setting. But right now in Vray 5 we do not have this value, so our HDRI is so bright that destroys the leafs and its transparency on the birghtest part of the image.
        Thank you.
        are you using any tone mapping there?
        Marcin Piotrowski
        youtube
        CGI OCIO config 04
          Are you referring to this fringing around the edges?
            Nope, im just referring that thin leaves are almost no visible anymore, later on with Vray 3.6 with the clamp value we do to fix it.
