masking values on bump mult not possible
  • masking values on bump mult not possible
    Hello, I noticed when connecting almost every node to the bump multiply in the Vray Material, it will set it to 0. Usually I would split an object by texture masks with a VrayLayeredTex into different areas and then connect the Layer R Channel (or message) to the bump mult to get various normal strengths.
    Is there a workaround without splitting the material?
    In the screenshots you can see the RGB mask, that is connected to the LayeredTex mask channels and each channel got an individual value but in the end I won't receive any normal detail anymore.
    (Maya 2023 and Vray 6)
ID:	1184510Click image for larger version
ID:	1184511Click image for larger version
    Just tested this and it works fine. I think the issue on your end is that your blending mode is set to normal, which means your textures overlap each other. Try using Add instead.
      Hey, thanks. Did you try it with a bump map or a normal map (tangent space)? I can, for example, only plug in the blue channel of my mask into the bump mult which should result in a normal detail with bump mult 1 on the cork of the bottle and no detail anywhere else. But still, whenever I plug in a color channel it will result in 0 normal detail. It does work with bump maps and normals in other spaces than tangent space though.
        Since the RGB channels are being used as masks, it shouldn't matter what the blending mode is. But, have you tried plugging them into the texture slots instead and indeed using an Add or Mult operation instead of going the masking route?
          Could you simplify the scene (a plane and a light should be sufficient) along with the texture and attach (or send) it so we can take a look?
