Rendering hangs at 100%
  • Rendering hangs at 100%
    This may have already been addressed in a previous thread but I'm not seeing it.
    The render is all but finished, it hits 100% and VRay hangs. No system resources seem to be used, everything from Disk to CPU and Memory is inactive or nominal, but the frame buffer is frozen and hangs for 2-3 minutes before finishing. No buckets are working on a thing, just dead time.
    Any known causes?
    This does seem to ease up, sometimes it's an issue, sometimes not. I'm concerned that it's a hardware issue, I have 96Gb of RAM, unfortunately, I learned that it's not the highest quality memory, maybe that's the problem?
    Thank you for any guidance.
    Windows 10 Pro
    ASUS Rampage V Edition 10
    Nvidia RTX 4090
    Intel i7 - 6800 @ 3.4GHz
    what resolution are you rendering at? And what file format are using?
    Website
    https://mangobeard.com/
    Behance
    https://www.behance.net/seandunderdale
      Thank you for the response, seandunderdale.
      Rendering at 7284x4096
      Saving to EXR (embedded), but not automatically. Just saving as needed from the VFB
        Do you have VFB lens fx and denoiser / sharpen on?
        Website
        Behance
          That's pretty high rez. Is it just taking a long time to write out AOVs etc? Minutes would certainly be a long time, but it can take a while especially if it's over a network.
          Edit: Never mind I see you're saving manually.
