Material override not working with VRay proxys
  • Material override not working with VRay proxys
    Hi
    Im not sure if this is a known issue or not but I could not find anything about it so I'll submit here.
    When adding VRay proxys to a renderlayer and add a material override to that layer/collection, VRay proxys ignores the override. I am not sure if its a bug or simply a feature that does not exist.
    We are currently using the following:
    VRay v6.10.00 from May 15 2023
    Maya 2023
    Windows 10 Pro
    I have submitted a ticket as well where I included an archived scene with a test scene that showcases the issue.
    Best regards
    /Rickard
    Works fine for me. Check if the proxy already has a material override in its settings.
      It has no material override in its settings.
      Small correction to the original post though. The proxy is reading a vrmesh, not an alembic.
        Try adding a Shader override instead of a Material override.
          Same result unfortunately . However, you can override it manually in the node editor. But that's a very destructive workflow and I would really like to avoid it.
            Could you attach a simple scene where the issue is present so we can troubleshoot?
              I have already submitted a ticket and attached a scene where I showcase the issue and linked this forum thread in the ticket. But I will attach the same scene to this post in case you don't have access to the first ticket.
              Thanks Aleksander!
                The proxy does have a material override already set. Go to the proxy > object hierarchy and scroll down to the "bulpPlant_A_shd". Click on it and remove the override from the menu below. We already know this may be tedious, so we've logged an improvement request (internal bug-tracker id: VMAYA-11288 ) for its improvement. I'll bump its priority.
                  Thanks a lot Aleksander!
