Min Shading Rate Is Not Found
  • Min Shading Rate Is Not Found
    Click image for larger version  Name:	2023-11-16 4.27.55.png Views:	0 Size:	117.1 KB ID:	1195131
    I just started using Vray and when I open the render settings, the minimum shading rate disappears.
    Do you know how I can get the display back?​
    Starts
    15-11-2023
    Ends
    19-11-2023
    Quoting the docs: "Min Shading Rate is removed from the interface and always uses the default value of 6. This is the optimal value for V-Ray and changing it usually comes at the expense of performance. Old scenes saved with a non-default value can still be adjusted​"
