Show Light Texture in Viewport is inaccurate?
  • Show Light Texture in Viewport is inaccurate?
    Hey All,
    Trying to determine if this is a VRay or Maya issue. The light texture preview doesn't appear to be accurate.
    I first tried using a file and then repeating the U value but it maps 1:1
    I then tried using a VRay softbox texture but it appears as solid white, and has 10 second long load times, for no results.
    Any tips for better previewing the end result? I'm trying to the eliminate the guesswork in my reflections.
    Thanks for any ideas!
    yep I had this issues before too. I had to viewport render my light to see how it was reacting before I could use it. Often what I do when bugs like this occur, is have a second version of Maya open, and test render assets like lights or whatever in that scene on their own. Get it setup how I want, then copy / paste it into my shot. Saves me having to deal with bugs and hacks in my shot.
    Website
    https://mangobeard.com/
    Behance
    https://www.behance.net/seandunderdale
      Yes, it seems the tiling is not considered for the preview.
      I presume this happens because of the re-rendering of both the viewport and the VRaySoftbox texture itself on each parameter change. I'll investigate further.
      For now, what seems like an adequate workaround is to either use a regular V Ramp.
        FYI, we've logged the issues for the tiling (internal bug-tracker id: VMAYA-12554) and slowdown - (internal bug-tracker id: VMAYA-12555). We'll log the VRaySoftbox preview one, too.
