Duplicated mesh turns black
  • Duplicated mesh turns black
    Hello everyone
    I'm a vray user for almost a year now and this never happened before..
    I was working with the trial version, where everything worked perfectly and today i bought the full version,
    then suddenly every object i duplicated (more specifically i made an instance via duplicate special) turned black
    this happened to a new file, as well to an old file where all the colors were already showing correctly.
    Has anyone encountered this problem before?
    would love your help Click image for larger version
Name:	Screenshot 2024-03-12 174013.jpg
ID:	1204242 Click image for larger version
Name:	Screenshot 2024-03-12 194932.jpg
    Try inverting the normals.
      I tried inverting normals, set to face, reversing the polygons... everything i could think of
        can you share the scene?
          https://drive.google.com/file/d/1PgO...ew?usp=sharing
            Try freezing transforms
              interesting.
              If you turn on interactive render it does look fine and it's not a poly issue it's the vray material. It could be a bug.
              I take it you want to continue manipulating to polys, so freezing is not an option.
              I would simply flip it .merge verts and use the mirroring tools to edit further.
              I can reproduce the same issue on a sphere in a new scene. if you apply default maya shader it works but applying vray material turns it black. Most odd
              I'd report it as a bug and see what they say.
              If you are done with editing polys then yes de-instance it then freeze polys.
                Yes i’m still working on it so that was the reason.
                Thank you so much for your advice and help, I will report it
                  The object has a negative Z scale, hence the blackness in the viewport (it renders just fine). So do what stezza suggested: finish your modeling, de-instance, and freeze transformations.
