VRayColorCorrection node to HDRI
  • VRayColorCorrection node to HDRI
    Is it possible to change the saturation of the HDRI in sky dome?
    Im trying to plugin in a colour correction node but cant seem to find where to plug it in.
    Thanks
    Not sure what you mean. Simply plug the File node into the VRayColorCorrection and set it as a Dome Tex. Note that the Saturation is 0-based (to decrease it, use negative numbers).
      If I plug the HDRI into the colour correct node, adjust saturation, noting changes none of the adjustments have any effect on the HDRI image.
      Works fine on texture files like png, jpg just not HDRI's.
        Works fine on my end. Mind if you attach your scene and .hdr?
          Your scene works for me, so must be user error, will dig in this afternoon.
            You've plugged the file itself rather than the VRayColorCorrection node in the VRayDomeLight.
              Thanks for that, yes user error again!
              Thanks for getting back I had it in my head that the file needed to be corrected before being feed into the dome light.
