Focus on proxy not working after latest update
  • Focus on proxy not working after latest update
    We updated to vray 6 update 2 recently.
    But now when we import a proxy we cannot focus anymore on the selected proxy in the viewport. When you select the proxy and press f then i goes somewhere out in the far space.
    Same thing happen when pressing a (zoom all) it goed out of space.
    This happens with proxies made with earlier versions. When we make the proxy again with this version of vray then it works okay.
    Hi, thanks for posting.
    This is not the case on my setup. I am using Maya 2024.2 and V-Ray 6, update 2 (latest from the website).
    Is the issue happening even if you create a new scene with a box and export the box to proxy?
    Vladimir Krastev | chaos.com
      It is the same setup as mine.
      But the thing is it happens with proxies that where created in an earlier version of vray and maybe Maya. So a large part of our library.
      When you export the proxy again in the latest versions all is good.
        What happens if you merge the older scene instead of open? Can you send us one of the proxies you have issues with?
        If you want to you can use the support contact form.
