Maya Keep crashing when I make a light or move a light in IPR with LightMix
  • Maya Keep crashing when I make a light or move a light in IPR with LightMix
    Looks like that LightMix feature is unstable.
    I just put a asset from Chaos Cosmos with a default render settings. The scene is nothing special.
    Maya 2024.2
    vray_adv_62001_maya2024_x64.exe
    Here is the log for the crashing, just for your information.
    Maya Crash Report
    Exception code: C0000005: ACCESS_VIOLATION - illegal write at address 0x00000000
    Fault address: 39353055 in C:\Program Files\Chaos Group\V-Ray\Maya 2024 for x64\maya_vray\plug-ins\vrayformaya.mll
    0001:00202055 Logical offset (see .map file for location)
    Call stack:
    Module: C:\Program Files\Chaos Group\V-Ray\Maya 2024 for x64\maya_vray\plug-ins\vrayformaya.mll (-exported-)
    Location: vrayformaya.mlluninitializePlugin + 77EC3 bytes
    Decl: class Autodesk::Maya::OpenMaya20240000::MStatus __cdecl uninitializePlugin(class Autodesk::Maya::OpenMaya20240000::MObject)
    Location: vrayformaya.mlluninitializePlugin + 6B256 bytes
    Location: vrayformaya.mlluninitializePlugin + 4184F bytes
    Module: C:\Program Files\Autodesk\Maya2024\bin\Qt5Core.dll (-exported-)
    Location: Qt5Core.dllQObject::qt_static_metacall + 1409 bytes
    Decl: private: static void __cdecl QObject::qt_static_metacall(class QObject * __ptr64,enum QMetaObject::Call,int,void * __ptr64 * __ptr64)
    Decl: protected: virtual void __cdecl QTimer::timerEvent(class QTimerEvent * __ptr64) __ptr64
    Decl: public: virtual bool __cdecl QObject::event(class QEvent * __ptr64) __ptr64
    Module: C:\Program Files\Autodesk\Maya2024\bin\Qt5Widgets.dll (-exported-)
    Location: Qt5Widgets.dllQApplicationPrivate::notify_helper + 110 bytes
    Decl: public: bool __cdecl QApplicationPrivate::notify_helper(class QObject * __ptr64,class QEvent * __ptr64) __ptr64
    Location: Qt5Widgets.dllQApplication::notify + 18B3 bytes
    Decl: public: virtual bool __cdecl QApplication::notify(class QObject * __ptr64,class QEvent * __ptr64) __ptr64
    Module: C:\Program Files\Autodesk\Maya2024\bin\ExtensionLayer.dll (-exported-)
    Location: ExtensionLayer.dllQmayaApplication::currentSystemM ouseButtons + 62C bytes
    Decl: public: static class QFlags<enum Qt::MouseButton> __cdecl QmayaApplication::currentSystemMouseButtons(void)
    Location: Qt5Core.dllQCoreApplication::notifyInternal2 + BA bytes
    Decl: private: static bool __cdecl QCoreApplication::notifyInternal2(class QObject * __ptr64,class QEvent * __ptr64)
    Location: Qt5Core.dllQEventDispatcherWin32Private::sendTimer Event + F9 bytes
    Decl: public: void __cdecl QEventDispatcherWin32Private::sendTimerEvent(int) __ptr64
    Location: Qt5Core.dllQEventDispatcherWin32::event + 149 bytes
    Decl: public: virtual bool __cdecl QEventDispatcherWin32::event(class QEvent * __ptr64) __ptr64
    Location: Qt5Core.dllQCoreApplicationPrivate::sendPostedEven ts + 215 bytes
    Decl: public: static void __cdecl QCoreApplicationPrivate::sendPostedEvents(class QObject * __ptr64,int,class QThreadData * __ptr64)
    Module: C:\Program Files\Autodesk\Maya2024\plugins\platforms\qwindows .dll (-exported-)
    Location: qwindows.dllqt_plugin_query_metadata + 1FBF bytes
    Location: Qt5Core.dllQEventDispatcherWin32:rocessEvents + 6A bytes
    Decl: public: virtual bool __cdecl QEventDispatcherWin32:rocessEvents(class QFlags<enum QEventLoop::ProcessEventsFlag>) __ptr64
    Location: qwindows.dllqt_plugin_query_metadata + 1F99 bytes
    Decl: public: int __cdecl QEventLoop::exec(class QFlags<enum QEventLoop::ProcessEventsFlag>) __ptr64
    Location: Qt5Core.dllQCoreApplication::exec + 154 bytes
    Decl: public: static int __cdecl QCoreApplication::exec(void)
    Location: ExtensionLayer.dllTapplication::start + E5 bytes
    Decl: public: void __cdecl Tapplication::start(void) __ptr64
    Module: C:\Program Files\Autodesk\Maya2024\bin\maya.exe (-exported-)
    Location: maya.exeTiteratorWrapperFwd<TscenePartitions::Cons tIteratorDescriptor,TiteratorWrapper<TscenePartiti ons::ConstIteratorDescriptor> >:perator++ + 1460 bytes
    Decl: public: class TiteratorWrapper<struct TscenePartitions::ConstIteratorDescriptor> & __ptr64 __cdecl TiteratorWrapperFwd<struct TscenePartitions::ConstIteratorDescriptor,class TiteratorWrapper<struct TscenePartitions::ConstIteratorDescriptor> >:perator++
    Location: maya.exeTiteratorWrapperFwd<TscenePartitions::Cons tIteratorDescriptor,TiteratorWrapper<TscenePartiti ons::ConstIteratorDescriptor> >:perator++ + 17E97 bytes
    Location: maya.exeTiteratorWrapperFwd<TscenePartitions::Cons tIteratorDescriptor,TiteratorWrapper<TscenePartiti ons::ConstIteratorDescriptor> >:perator++ + 16E16 bytes
    Module: C:\Windows\System32\KERNEL32.DLL (-exported-)
    Module: C:\Windows\SYSTEM32\ntdll.dll (-exported-)
    End of stack
    Thank you.​
    Just tried it and seems ok my end.
      Thank you for your help.
      Here is the video for the problem.
      https://www.youtube.com/watch?v=U_q5QTrSczc
        The crash is reproducible. I'll log it
        EDIT: Logged (internal bug-tracker id: VMAYA-12823)
          Thanks a lot!
