About Vray Decal & Displacement
  • About Vray Decal & Displacement
    Hello. I'm having trouble with Vray. Version V-Ray 6 for Maya, update 2.2​
    When using Vray Decal, shadows resembling the Vray Decal's bounding box appear on objects using Displacement. This occurs when using Vray Sun or HDRI with a strong light source, but it is less noticeable with flat HDRI images of cloudy skies. Is there a solution to this?
ID:	1215332 Click image for larger version
ID:	1215333 Click image for larger version
ID:	1215334 Click image for larger version
ID:	1215335 Click image for larger version
    Hi, thanks for posting.
    Do you have displacement in your material for the Decal?
    Please test these options in the Decal:
    It will be best if you could share your scene. Please do that here or through the support tickets.
    Vladimir Krastev | chaos.com
      Thank you for reply.
      I tried it, but unfortunately, it didn't solve the issue. I have contacted support.
      I checked alpha values of the textures, and the Decal settings, but I couldn't fix it.
      Also, after checking with AOV, this result is only affects the lighting pass.
      I will wait for a response from support.
      Thank you.
        Hi, you hit a previously reported bug with this scene (reported under VMAX-14234 in our system).
        This is the other thread about the same bug.
