VrayDirt - As Inclusive Set default to off
  • VrayDirt - As Inclusive Set default to off
    Hi all,
    Is there a way to change VrayDirt so that 'As Inclusive Set' is OFF as default?
    As it's on as default, I always end up rendering and my dirt element comes out completely empty, meaning I have to re-render quite often. (Yes, I should remember, but these things happen...).
    If the "Affected By" set slot is empty, there shouldn't be a problem, regardless of the "As inclusive Set" option. Is this not the case on your end?
      Unfortunately it doesn't work that way here... 'As Inclusive Set' is always on as default and the element renders out competely white.
      I'm running 4.6.20.02 on Maya 2025.2.
        We will change it on our side
        Best,
        Muhammed
        Muhammed Hamed
        V-Ray GPU product specialist
        chaos.com
          Brilliant, thank you, much appreciated!
