So many attributes in Vray seem to not work with keyframes. Ive made loads of posts about keyframing different things, that work ok in RT, but then dont work for final render. Its impossible to know if something will work without testing it as a final render, which uses up production time...thats what RT is meant for!
Ill often use frames to setup different types of renders I need, as its sometimes quicker and less buggy than render layers can be. So Ill keyframe the colour mode on the Sun and sky shape from "filter" for frame 1 to "override" on frame 2....works in RT, doesnt work in final render....also an object property group...off on one frame, keyframe "disable" so it turns on...works in RT, doesnt work in final render.
Unless Im making some kind of workflow error, itd be great to know why Vray doesnt have very keyframable attributes on so many things. Is it a Maya thing?
