I have a ball and I want to animate a ramp that should build a transparent circle.
Somehow there is no way to make a transparent the VRayFastSSS2
The circle that is now brown needs to be transparent i can see the red circle behind.
Those anyone know how to solve this issue?
I already tried to use the blend material, but the base color does not have a slot for transparency as the other added slots of materials.
The texture layer does not work either.
I tried also to connect my VRayFastSSS2 into the diffuse of a new vray material and nothing will transparent.
So, how does the VRayFastSSS2 can be transparent in the desired areas (in my case in a circle form using a ramp)?
BTW. the green skin is also terrible! And this color is coming form the "MAYA texture layer" Yes I also used the maya texture layer to do some test.
EDIT:
BTW I'm using this as a skin shader so mein VRayFastSSS2 ist set as:
Color Mode = Sub-surface color and scatter radius.
with:
Single Scatter = Single
Why the VRayFastSSS2 does not have any slot for transparency !
It is a material and nees to be also manipulate in all forms .
EDIT:
with:
