Lock Fresnel IOR
  • Lock Fresnel IOR
    Are there some known issues in Vray 7?
    The tickbox does nothing here.
    https://linktr.ee/cg_oglu
    Ryzen 5950, Geforce 3060, 128GB ram
    There were some changes regarding its relation to Metalness - documented here. Basically, when you have Metalness on, the fresnel is calculated based on the diffuse and reflection colors.
    If you mean that the Fresnel IOR option stays greyed out, I'll log it. If you uncheck the "Lock" and afterward uncheck and check the "Use Fresnel" it should get back to normal.
    EDIT: Logged (internal bug-tracker id: VMAYA-13372) the UI thing.
      I see no reason why it shouldnt work. Maybe im missing something?
        As I said, that's a UI issue. Untick and tick back the "Use Fresnel" and it will become available.
        EDIT: It's fixed in today's nightly.
